Re: Massey 1135 Eating PTO Clutches
brianriver
08-23-2007 08:54:42
Pretty strong clutches. Sounds like you have had the clutch drum isnspected, make sure no grooves or sharp edges. Is the clutch engaging smoothly and not with a jerk to rip teeth off? Any jerking motion on what the PTO is driving? Probably have already thought these. Let us know if or how solved.
Briar Creek Stables
08-24-2007 05:46:05
 Re: Massey 1135 Eating PTO Clutches in reply to brianriver, 08-23-2007 08:54:42
I did inspect the drum and cleaned all the shards from the old clutch out.
The clutch engages very soomthly. No unusual sounds. No sliping. It apears to be a normal running clutch.
I went over my equipment and everything seems to turn over just fine by hand. The only thing I can really think of that might of cause some jerking is the bailer. When the cutter on the bailer cuts some of the heavier hay, I'm sure that has to add a little stress to the pto. The knife apears to be cutting well and seems fairly sharp. I'll sharpen it up a little more just the same. I have broken a few shearbolts on the heavy hay. I'm using a low grade shearbolt, it breaks a little to often, but better than replacing a plunger arm.
This thing deffinately makes me stand back and scratch my head. I was a John Deere mechanic when I was in my 20's, can't say as I ever run across anything like this. Usually if there is something in a tractor tearing clutches, it's rather obviouse what it is when you open the thing up. I ran into this on an old deere once and it was the pto gear missing a tooth.
