Re: MASSEY HARRIS HYDRAULIC LEAKING INTO OIL PAN
Login
12-21-2007 20:13:34
If you never fixed it yet its real simple take your hydraulic pump loose from the tractor & split the pump apart & a 35 cent oring will fix your problem I have done several I noticed mine when the rear seal started leaking because all the htdraulic oil went in there GOOD LUCK & keep the massey legacy going.
