MF135 clutch alignment tool MF159A
Neil Mc
03-03-2008 03:58:28
Hi,
I have split my MF135 to replace clutch thrust bearing, and would also like to remove clutch to look at rear main seal. Does anyone know what special tool MF159A looks like, or what I can use to align the clutch and plate. Thanks.
Neil Mc
Neil Mc
03-03-2008 20:45:56
 Re: MF135 clutch alignment tool MF159A in reply to Neil Mc, 03-03-2008 03:58:28
This is an excellent forum! Thanks for the help.
Ian in Jersey
03-03-2008 14:46:40
third party image
Hi Neil,
Clutch aligning tool MF159A is for the later MF135 tractor which has 10" and 12" clutch friction discs for the PTO and main clutches, according to the workshop manual.
If you have an earlier 135 with 11" and 9" friction discs, the aligning tool I borrowed from our MF dealer is the same as for the MF35: part No. MF159B/1. I do not know if the two aligning tools have the same dimensions despite their different part numbers.
Here are the clutch tools for the early 135, with dimensions:
Neil Mc
03-03-2008 20:31:16
 Re: MF135 clutch alignment tool MF159A in reply to Ian in Jersey, 03-03-2008 14:46:40
Thanks Ian, that gives me a good idea how it should look. I plan on making something temporary, Aaron Ford's piccy looks like it might be the way.
Cheers,
Neil Mc
Aaron Ford
03-03-2008 06:40:39
I made mine out of a 1/2 inch all thread and various sockets to line everything up. If you look back at some of my posts, I described it completely, but alas, I have forgotten how I did it. I will look and see if I can find it. here is a pic anyhow. Aaron
third party image
third party image
Neil Mc
03-03-2008 20:40:02
 Re: MF135 clutch alignment tool MF159A in reply to Aaron Ford, 03-03-2008 06:40:39
That looks excellent Aaron, only needs to work once!
Neil Mc
supergrumpy
03-03-2008 13:10:03
gears on my 135 grind and sounds like I need to adjust my clutch thru the bottom opening
are those bolts in the ends of the 3 fingers the ones you adjust to set the gap at .080???
Aaron Ford
03-03-2008 06:44:59
 Here it is! in reply to Aaron Ford, 03-03-2008 06:40:39
I found it.
DavidP, South Wales
03-03-2008 05:05:54
Hi Neil,
The tool is virtually a plain version of the input shafts that go into the gearbox. If you have access to a lathe it is easy to make one.
The smallest dia which goes into the flywheel bearing is essential. Ingenious people have made them from other materials besides metal. Don't forget to fit the 3 2 1/4 inch 1/4 unc bolts before removing the clutch cover.
Neil Mc
03-03-2008 20:42:35
 Re: MF135 clutch alignment tool MF159A in reply to DavidP, South Wales, 03-03-2008 05:05:54
I will caliper the inner splines and the spigot shaft and see what I can use. The 3 1/4 UNC bolts I will have to get from my nut and bolt shop, which is a goodie.
Cheers,
Neil Mc
