Got 'er Fixed
skycarp
05-03-2008 17:30:44
Well, I couldn't find a fill point so I made one.
I drilled the rectangle plate next to the shift pattern on the top cover to allow a 1" pipe plug to fit into the hole. I threaded the plug into a short piece of pipe collar on the underside, then welded the pipe collar to the plate. It isn't original, but other things on the tractor are done the same way over it's life. See pictures:
Top side
third party image
Under side
third party image
