Points for 12 volt conversion
Rich
10-16-2000 14:31:37
I'm converting my '49 8N over to 12 volts. I read the instructions that is in the research & info section and it doesn't say any thing about changing the points. I'm doing this I hope the cheap way. All I had to buy so far was the front mount 12volt coil, and making all the brackets.Are there 12volt points and condenser for this? Thanks Rich
laj
10-17-2000 05:56:37
 Re: points for 12 volt conversion in reply to Rich, 10-16-2000 14:31:37
Rich, you should read this thread.
JerryU
10-16-2000 17:19:57
Points and condensor will work. Personally, I would still use a resistor with the 12volt coil. The one I have says anything over about 13 volts needs a resistor. With an alternator you can climb up in voltage. Have had the same coil on for quite a few years with no problems. Another well known fellow on the board who has been known to find extraneous aluminum beverage cans about his tractor also has a 12 volt conversion with a 12 volt coil and uses a resistor. Study wiring diagrams and be sure the circuit includes a marker light or diode or your tractor will like running so much it won't shut off.
Like Claus said, save the old parts--I couldn't mine came with a conversion (sloppily done that had to be reworked).
JerryU
Mark
10-16-2000 15:30:47
Rich,
I am going to convert my 8n to 12 volt also. I was wondering what front mount coil did you get and where can I get one.
Thanks and good luck
Mark
Claus
10-16-2000 14:52:37
If the old parts are in good shape, keep em...
Happy Motoring
claus
