Re: REAR ARMS FOR DRAW BARS
PHILIP SEARCY
03-22-2002 06:50:34
THE STABILIZER BAR KIT WORKS GREAT WITH BOX SCRAPPERS, MOWERS, BUSHHOGS, BUT ARE AN ABSOLUTE MUST WHEN USING A GRADER BLADE OR BOOM POLE. THE KIT CAN BE PURCHASED FROM TRACTOR SUPPLY. YOU WILL NEED TO BOLT A MOUNT TO THE BOTTOM OF THE AXLE UNDER EACH FENDER. LONGER FENDER BOLTS MAY BE REQUIRED. THE STABILZER BARS RUN FROM THE MOUNT TO THE IMPLEMENT. LET ME KNOW IF YOU NEED ANY PICTURES OF THE COMPLETED ASSEMBLY.
