Take a look at the wheel brgs.
Rob
08-15-2004 05:37:09
Front wheel bearings should be repacked with short fiber grease and adjusted every 600hrs. If they haven't been done that way or you don't know then pull the dust cap, remove the nut, pull the hub, inspect, repair as needed, repack, adjust, and see what you got. Need to do it anyway and it might fix your problem.
