It makes perfect sense. Always helps to
Rob
09-12-2004 11:17:28
have oil in there.
LDogg
09-12-2004 11:26:10
 Re: It makes perfect sense. Always helps to in reply to Rob, 09-12-2004 11:17:28
Yeah - I knew I would get an answer like that. Thanks. Actually it was just low on oil. My biggest concern was the amount of air bubbles.
Rob
09-12-2004 11:33:33
 Re: It makes perfect sense. Always helps to in reply to LDogg, 09-12-2004 11:26:10
Sounds like you're good to go. One thing, some guys never fill it plumb full. They fill until it comes out that bolt hole in the bottom of the round mounting plate the dip stick hangs out. That way the fluid never gets on the rear axle seals to leak out all over their brake shoes and rim. Look at the inside of your rear wheel disks and drums and if it's yucky oil and dirt then lower the fluid level some.
