The control should stay where you put it.
Rob
09-24-2004 15:49:39
You shouldn't need to hold it down. You need some adjusting. There's a tension adjuster on the touch control lever and there should be a cork gasket between the round plates to accomodate that tensioning. I put 1/16" of rubberized fiber material in place of the AWOL cork.
You should have a mechanical sliding stop on your touch control quadrant that prevents the lever from moving up; might not reach that low. Get with the FO-4 or 8N Operator's Manual and spend some time adjusting that touch control.
