Know what? Maybe you don't have to
Rob
09-24-2004 18:03:48
fuss over that packing. You can adjust that packing. You turn the valve stem in a turn or two, tighten the packing nut snug and check to see that you can't turn the stem. Then back off the packing nut just an 1/8" turn or so til the stem turns and fiddle with the nut until the valve stem turns with reasonable force. The stem will loosen with use and you can always tighten the packing nut.
You probably don't need to replace that packing.
MikeT
09-24-2004 20:00:08
 Re: Know what? Maybe you don't have to in reply to Rob, 09-24-2004 18:03:48
Yeah, I cleaned it up a bit and stuck er back in. Maybe good for another 52 years!
Gees, this post don't sound very good!
