Yeah, that old junk planter...
Rob
09-30-2004 17:07:12
has some good iron on it. I think the piece can be straight, it's the holes in it that are hard to come by. Anything, so the bar can't twist.
Fact is, I pulled trailers before I put that iron on there. Pulled them from a ball too. It only twisted so far. I wasn't pulling but a few hundred pounds though.
If you have a clevis on the hay trailer you won't need a lock.
Stickler
09-30-2004 17:56:43
 Re: Yeah, that old junk planter... in reply to Rob, 09-30-2004 17:07:12
hay wagons usually don't use a ball mount, but a clevis. Anyway, my version of the eleven holer drawbar is home made and has welded tabs to stop it from rotating. They just sit under the lift arms. I've pulled my 4000 pound camper with it with zero probs. yes, you need the adjustable link bars or mine are solid, to keep the lift arms from rising when you back up.
