Too much choke.
Rob
10-03-2004 15:36:30
Warm weather you probably don"t need any choke at all. Always try before you use any choke. Hold it on more then couple-three turns and you get gas running out the carb air intake. Called flooding it. 9N/2N manual says pull on the choke and "immediately" release it.
Cold weather that is a big problem.
If an N won"t start with just a little bit of choke you"re much better off correcting the problem than using more choke and flirting with flooding, especially if you expect it to start near or below freezing.
