Stuck clutch and grinding gears
Rob
10-05-2004 07:34:57
I've got a clutch on the bench. It wouldn't disengage and there is nothing wrong with the clutch. The shifter fork is pinned to the clutch release shaft but the shaft was wallowed out. I lost 1/2" travel in the throw-out bearing so the clutch never really disengaged. On top of that, the right end of the shaft and the bushing is worn so there is more slop there.
Symptoms would be that you can adjust the clutch any way you want but the clutch will not disengage or it drags causing grinding gears when shifting. That's backward from normal where you adjust when a clutch wears and starts slipping until all the adjustment is used up.
The fix is an engine/tranny split to repair or replace the $15 shaft and replace the $5 split bushing and $2 pin. Me, I'll probably bush the wallowed shaft and make a pin.
