OK - I am confused
Peanut
10-05-2004 08:36:03
I think I am really in the dark here. I don't understand what a MIG welder will handle that a high-amp stick welder wont. Is it the thickness of the metal and/or the type of metal? I suppose I will eventually weld something that needs structural integrity but will start off with small stuff (including the front bumper on my 9N ... the bumper broke off from the bolt-on part of the bracket.)
I have seen plenty of used Lincoln 225 stick welders (and even new aren't too awfully expensive).
souNdguy
10-05-2004 12:22:15
 Re: OK - I am confused in reply to Peanut, 10-05-2004 08:36:03
Another thing that makes the stick nice is if you need to change elctrode material often. With a stick welder you can weld with a different electrode on each pass... 7018 6011 6013.. etc.. etc.. chamfer rod, ( (gasp) aluminum... ).
on a wire welder I think you'd be going to alot of trouble to change out wires....
Wind is a big issue as well. Also not sure if you can cut with a wire welder.. course cutting with an arc welder is more akin to cutting with a chainsaw.. Another option for welding is different environment. A buddy of mine does marine salvage.. and they use arc welding underwater.
Soundguy
lonestarjeff
10-05-2004 09:09:06
Both types of welders depend on power for depth of weld, so either type will do what you"re talking about if you pick one w/ enough power.
Mig is usually easier to learn because of the way it delivers the electrode at a steady pace. I can make a pretty decent looking weld w/ a mig,
But put a stick in my hand & I"m all over the place....deep, then shallow, puddle, skip-skip(you get the picture). Put a stick welder in the right hands though, it"s a beautiful thing.
Jeff
Bob
10-05-2004 08:42:31
The MIG is more for production use, with clean metal. It's quick, as you don't have to stop and change welding rods, and it produces a neat, clean weld, so there's little need for schipping or brushing to check the weld, or for repeat passes.
A good stick welder is just fine for repairs and heavy welding, but takes more experience to weld thin sheet metal with than a MIG. For use outside, the stick will work with some wind, where it's tough to weld with a MIG in a breeze because the shielding gas gets blown away from the weld area.
