Try a jumper around the ignition
Rob
10-10-2004 10:18:02
switch. Might be bad switch. Get a new one don't hang a key chain on it, just the one key and install it with the pins on top and it might last longer.
Check the spark when it craps out and needs choke, might be the coil. You need a snappy, blue spark and a yellow spark isn't a good spark.
Bend the plug wires and if they show any surface cracks get new copper-core wires and that might fix it. 5-strand or 7-strand copper is fine.
