Might be running way rich.
Rob
10-12-2004 17:30:20
Turn in (CW to lean) the main adjust on top front of the carb see if the smoke clears. You'll know right away. 1/4-turn might be more than enough, maybe 1/2...give it a try.
FYI: When you go to set up that carb you start at one-turn out. Usually ends up near 1-1/2 turn out maybe less. On a good engine, when you goose the throttle to 1/2 and the engine stumbles it's too lean, if it puffs it's too rich.
