Guv'nor top bolt?
8ngreenhorn
10-23-2004 05:10:26
Do I take that top bolt off first? What's the point with it?
Bruce (VA)
10-23-2004 07:36:39
 Re: Guv'nor top bolt? in reply to 8ngreenhorn, 10-23-2004 05:10:26
There are only 2 bolts that hold the governor on; one is shorter than the other and it goes on top. If the tractor was running and you removed the 2 bolts and they are both the same length (which I doubt) then someone replaced the longer bottom bolt with a short bolt. But, I do not think that is possible.
Drmeatman
10-23-2004 05:30:15
Greenhorne,don't know if there is importance in which bolt comes off first,top or bottom but I loosen both then take off the bottom first. The important thing and I draw attention to importance is mark your top bolt for correct replacement.The top bolt is "shorter" and it's that way for a "big" reason.Big blot on top shears the teeth off your cam gear.Hope this helps. "C"
Ramrod
10-23-2004 05:23:58
We're working on that over here --
