Hey Phillip No, I won't be at the Louisville show. I always go to Moultrie, GA, but they never send me to any of the others. If you are there, ask for a guy named Raymond Bullock, he's a close co-worker of mine. Also, you'll see some giant 8'x8' panels against one wall that they had me work on. That is, if we can get them to stand up on their own. As for the guard, we can't burn anything that small here. We had a sheet metal nibbler that would do it perfectly, but it's unplugged right now and in another building. As soon as it's back up, i'll get one made. The bad thing is, when I had them shop blast my blade, it warped the heck out of it and now it wobbles about an inch side-to-side from heat warpage. I'm going to try to push and tug to get it back reasonably straight, but i'm also considering sources for a new blade or blade repair. Could you give me any heads up on your springs and bolts for the table? I went back and looked at your pictures and it looks like you drilled an extra set of holes closer to the bottom for the springs so they wouldn't have to be so long. Is that true? Thanks! Jeb
