Lift Shaft Bushings
Rick H. Ga.
02-17-2005 09:50:56
Great Advice!!!
Ask me how I know.
Rick H. GA.
GAJIM
02-17-2005 10:22:06
 Re: Lift Shaft Bushings in reply to Rick H. Ga., 02-17-2005 09:50:56
Amen! When I had the lift apart a few months ago on my '52 8N to replace the lift cylinder, piston, and seals, I pondered replacing the shaft bushings. But once I took a hard look at it, I changed my mind fast. It looked like I would end up breaking something just trying to get it apart.
I cleaned out the sump real good, refilled with 90 wt. GL1, and replaced the shifter boot. Since I'm in the process of building a new house where the N stays and don't have a garage or barn to park it in, it's out in the weather all the time. The rear oil still is as clear as the day I put it in there; no sign of any moisture leaking in. If it ain't broke, don't fix it. You might tear something else up fixin' it. GA Jim
