Too much choke floods the carb and you get gas
Rob
03-23-2005 17:07:27
running out. It won"t start if it"s flooded. It has to dry out. If it"s cold you almost need to put in fresh plugs after you flood it. I flood it I might refresh the plugs by washing them in Dawn dishsoap. It"s a great grease and oil cutter. Anyway...
pull a spark plug and ground it to the head. Crank the engine and look for a snappy, blue spark. A whimpy, yellow spark is no good.
If it"s a yellow spark then it"s an ignition problem.
