takes only 'bout 3 gallons
8ngreenhorn
04-14-2005 09:27:15
I remove all three plugs beneath and the side drain below pump. Put it in slowly, but only about three gallons go in before it flows out the side port.
Steve (Magnolia, TX)
04-14-2005 09:59:38
 Re: takes only 'bout 3 gallons in reply to 8ngreenhorn, 04-14-2005 09:27:15
You might consider the benefits of draining all 3 (sub?)compartments and washing it out with some diesel (or kerosene, the solvent of your choice) several times. Don't be afraid to get your hand in there and work loose that gallon and a half of sludge that stuck in the bottom there...
Then refill with fresh oil.
HTH
Steve
Russ SoCal
04-14-2005 12:21:28
 Re: takes only 'bout 3 gallons in reply to Steve (Magnolia, TX), 04-14-2005 09:59:38
And make sure the tractor is on relatively level ground.
R
