Dell (WA)'s diagnostics
Russ SoCal
04-23-2005 00:37:03
Runs one-minute and quits = condenser. Starts up again and quits again.
Runs three- to five-minutes and quits = fuel line screens. Will stumble and not start unless you wait a few or several minutes.
Runs 15-minutes and quits = ignition switch. Will restart or not after some several minutes. It will do it again after lunch.
Runs 40- to 60-minutes and quits = front-mount coil. Needs to cool off for an hour or so.
mandolin jon
04-23-2005 01:54:50
 Re: Dell (WA)'s diagnostics in reply to Russ SoCal, 04-23-2005 00:37:03
Thanks for the input guys. I think it is the coil because of Del's diagonsis fits. The spark plugs are new. I just recently reset the points but I didn't replace the condensor. However, the coil is older than the points and condensor which were new when I got the tractor. It don't think its gas line problems because I have gone through that check.
