POR-15
Russ SoCal
05-02-2005 09:45:15
BG,
I used the POR-15 kit a couple months ago. Seems like it did real good. Only complaint is the amount of time to soak, turn, soak, turn, ad nauseum. One of the steps says to use HOT water, then leave it in the tank for hours and hours, turning it every which way to get all surfaces. Must be for folks in Death Valley in August.
Russ
BigGeorge
05-02-2005 12:51:11
 Re: POR-15 in reply to Russ SoCal, 05-02-2005 09:45:15
Yea I hear you Russ. I used boiling water but it only stayed hot for about 20min in the tank. Today after numerous rinsings and drying I put in the "metal ready" (phosphoric acid). It says to leave it in for 30 min then check to see if rust is gone. Well its been in about 5 hours now and I still see rust. Does anything ever work the way its supposed to work?..... .... BG
