Does not compute, does not compute
Russ SoCal
05-13-2005 20:04:03
"pretty good spark until @ very low rpm's. When I wind her up it cuts to no/intermittent spark."
That reads like both ends of the rpm range have unsatisfactory sparkies.
Got a voltmeter? With engine off, key on, what's your voltage at the top of the coil? Bump the engine or rock the tractor until the points either open or close. Should see readings of little over six volts (battery voltage) and about 3 volts. Also check your rotor and cap for contact abuse. How are the distributor bushings?
Russ
