Mike and Jeff
Russ SoCal
05-29-2005 10:44:43
No it won't prime from the oil filter. What goes over to the governor just dribbles back in the sump. What could go back therough the line to the rear corner of the block would run out of the pump much faster than the line could supply oil. The relief valve cap is 15/16ths inch hex, just to the left of a front mount distributor coil and slightly below and to the right of the water pump. Suggest using 90 weight oil, quickly replacing the cap and cranking the engine before the pump loses prime again.
Russ
lonestarjeff
05-29-2005 15:44:11
 Re: Mike and Jeff in reply to Russ SoCal, 05-29-2005 10:44:43
Russ:
Thanks for the quick response, I read the fill the oil filter idea somewhere else, it sounded logical, but I wanted to be sure before I start mine after 20+ years.
Jeff
