Order Ford 8N Parts Online
8n clutch info needed
Roger in Iowa
07-04-2005 18:33:58
No I have not tried that.
Where is the timing hole?
Roger in Iowa
Bob
07-04-2005 22:44:55
 Re: 8n clutch info needed in reply to Roger in Iowa, 07-04-2005 18:33:58
Only side-mount distributor engines have a timing hole, in the RH side of the bell housing.
If your's is a front-mount, you're out of luck!
Roger in Iowa
07-05-2005 06:18:57
 Re: 8n clutch info needed in reply to Bob, 07-04-2005 22:44:55
Yep, it is front mount.
Need to know the distance from the split at engine to trans to the center of the clutch disk. Anyone got an engine with clutch attached that can make this measurement?
Thanks,
Roger
