Problem Solved
pkebs
08-27-2005 16:35:24
I reinspected the plow since I found out it was not the hydraulics. It"s an older plow, and the root must have knocked the mould board loose from an eye bolt in the back, this allowed dirt to cake behind the mould board, throwing the pitch of the plow off. I cleaned the plow and retightened the moldboard. It seems to be working again. These eye bolts and mould boards seem to be in pretty rough shape. I haven"t had the 9n very long and got the plow, disc, scrape blade, and layout plow for less than $1500. The tractor runs and works great other than a few leaks here and there.Any suggestions for finding replacement parts for this old plow? Thanks for the help guys!!
lonestarjeff
08-27-2005 18:58:29
 Re: Problem Solved in reply to pkebs, 08-27-2005 16:35:24
Sounds like you got a good deal. Lot of folks pay more than that for just the tractor.
Jeff
Scott PA
08-27-2005 18:02:23
Click on my name to email me for help to locate parts for the plow if it is a Ferguson, Dearborn or Ford, I need the numbers off the back of the point (share) or moldboard to tell what style you have.
