Stupid Questions...
Alan R
11-27-2005 09:13:00
Stupid question #1: To remove the oil pan can I support the gearbox and unbolt the front end without disconnecting it completely? Stupid question #2: What's the easiest way to tell what kind of sleeves I have, steel or iron? According to the I&T Shop Service manual the serial # of iron sleeve engines has a diamond before and after the number, while steel sleeve engines have a star before and after the serial number. This brings me to stupid question #3: Where is the serial number? I see a small plate near the starter that MAY read 1730 and below that a large 8N-B. According to the manual, converting steel sleeve engines to iron sleeves requires a machine shop. Is that true? How difficult is it to replace the sleeves if I have iron to begin with? Is a sleeve replacer tool available? Sorry about all the questions, looks like the in-frame engine kit would work for me, assuming I can replace the sleeves myself. Thanks for any other tips, comments, advice concerning the repairs.
Dell (WA)
11-27-2005 10:00:09
 Re: Stupid Questions... in reply to Alan R, 11-27-2005 09:13:00
Allen..... ....answer to question #1 = yes. Yer tranny will support yer engine after you remove yer front axle.
Answer to question #2 = I don't know until you try and remove the sleeve and you can't peel the castiron but can the sheetmetal sleeve.
Answer to question #3 = 1x4" flat spot just under the cylinderhead gasket with weakly handstamped numbers. The 8N-B tells me you have a 5-nipple sidemount distributor and 1730 is the block casting date of 17 Mar 1950 (I think, but don't care) Sidemount engines started production in early 1950.
Answer to question #4 = yes. While the N-Pistons are the same diameter, steel or castiron sleeves, the thicker wall (0.090) of the castiron sleeve DEMANDS the cylinder block be "bored-out" to accomodate it. Castiron sleeves have better wear and sealing characteristics than the harder thiner steel sleve.
Answer to question #5 = yes, good machine shops have specialize sleeve removal and replacement tools. Remember the sleeve is an "interference-fitt", meaning it is slightly bigger'n the hole it fitts into. I like to recommend making a sleeve spool outta plywood disks and all-thread rod. Fill the spool/cylinder cavity with dryice chips. (yellow pages) The -100F dryice will shrink the sleeve for eazy fitment. Works for eather steel or castiron sleeves. Simple, eh?
Comment: gitt an I&T FO-4 manual, $22 (cheap)..... ..respectfully, Dell
