12 volt conversion
ricko7001
12-18-2005 10:52:08
Can someone give me a simple rundown on how to convert to 12 volt on an 8n with front dist. Tried it and have no fire??
Dan Hill
12-20-2005 02:45:42
 Re: 12 volt conversion in reply to ricko7001, 12-18-2005 10:52:08
Have you noticed that most problems on the forum have to do with 12v conversions.
Rob
12-18-2005 11:17:44
You have juice to the coil? Take off the wire, turn on the key and brushs the wire to ground to check for spark.
You need to start and work from there.
12v conversion shouldn"t kill power to the coil unless you took some wire off and left it off.
You add any resisters?
Forget about the alternator for now, find out just where you have juice and why it can"t get from the battery to the coil. It goes through the key switch you know.
ricko700
12-18-2005 11:26:23
 Re: 12 volt conversion in reply to Rob, 12-18-2005 11:17:44
does it matter what type coil I use so long as its 12 volt without resistor or 6 volt with resistor..does it matter what type alternator I use. Dont have a key start just a push button on dash..the floor mounted one supposedly doesn twork
souNdguy
12-18-2005 14:27:37
 Re: 12 volt conversion in reply to ricko700, 12-18-2005 11:26:23
A square 12v coil still needs about 1/2 ohm of external resistance. The square 6v coil needs both the ballast resistor and the 8ne10306 dropping resistor.
As the others said.. you need a non momentary ignition switch.. as well as a starter switch. They can be one inthe same if you have added a 'regular' starter relay, and use 3 3 position spring loaded auto style ig/st switch.
Soundguy
Rob
12-18-2005 11:47:18
You need something more than a push button.
You need to close a switch and leave it closed to put juice to the coil. That"s all the ignition switch does. Push button won"t do.
Really, find out if you got juice to the top of the coil. You won"t because you don"t have a switch.
Some alternators are as good as any and some need an external regulator. You need to add a resistor or two with a 6v coil. Dell says you need to add resistors for the 12v coil but not just to get juice to the coil. But that is jumping ahead. Take one thing at a time.
Get juice to the coil and worry about whether the alternator is charging later.
Bob
12-18-2005 11:12:01
Are you using a Delco 10SI 3-wire alternator?
What coil are you using, the original 6-Volt, or a 12-Volt replacement coil?
