I'm amazed
Ron/PA
05-26-2006 04:08:55
I just went back and looked at your original post, and here's what I see. You posted a problem, gave little or no information, asked about testing the coil, and rebuilding the carb. It appears that rather than doing the diagnostic run time and spark tests, which would have answered your questions, you chose to throw money at it, replacing parts. Had you posted the results of those tests, you might have gotten a lot more precise advice. Eventually someone might have even told you to pull the plug on the carb. Since it appears a simple cleaning did the trick, I know that the process for that has been posted on here a bunch of times. You might have taken the initiative to search the archives for that info. Having spent my whole life actually working with these N's I still won't try to diagnose a problem long distance, and for those that do, I'm amazed at their accuracy, and the amount of information they dispense to keep repair costs to a minimum. Josh, I'm sure you'll live, but I have some serious doubts that you have or will learn.
Ron
