Here's the text of the post, and a link to the thread with the post in it: You are certainly having the symptoms of a overheated coil. You can verify if it is ignition or "vapor lock" by checking for spark immediately after it has heated up, stopped running, and won't start. I would have used "Dell's Trick Resistor ahead of the coil. The Pertronix folks are giving the OK to run without a resistor, based on what their MODULE will tolerate, and they must not have figured out what a delicate piece of @*$^ most of the generic "12-Volt square-can coils" are. At this point, you can try adding the resistor, but the coil may have been overheated to the point where it is permanently damaged. Then, you'll have to start over with a new coil AND a resistor. I see no reason NOT to try "Dell's Resistor". The added resistance certainly will not cause any damage, the worst result with too much resistance will be weak spark, but the worst result of NOT enough resistance in the circuit will be a failed coil, and then, possibly a failed module.
