HEY DELL
ron francis tro
05-30-2006 08:21:23
I don't want to drive to Oxnard to Staben Equip to get a key switch..... ...What retail outlets do you know that carry them? Pep Boys doesn't have it..... ....except I could get a newer type key switch there..... ..
Dell (WA)
05-30-2006 08:42:24
 Re: HEY DELL in reply to ron francis troncatty, 05-30-2006 08:21:23
Ron..... ..ever wonder why I call the OEM ignition switch a weak sister? One summer, I replaced the ignition switch 3-times (and I know how to do it right) The 3rd time, I bought a 25-amp waterproof marine grade toggle switch and haven't had problems since. Keys, eh? who needs 'em?
You just haffta make yer own short wires to connect to the terminal board from the non-stock ignition switch. (which can be a problem to the electrically challenged) Of course, you can also use enny replacement ignition keyswitch yer local autoparts store is selling. (which can be a problem to the mechanically challenge because it don't fitt the key bracket hole) Iff'n you can read the instructions on how to wire it, it will usually have criptically labled terminals like BAT, IGN, ACC, ST. Are you man enuff to handle that?..... ..respectfully, Dell
Bob
05-30-2006 08:29:42
Before driving ($$), and purchasing a new switch ($), simply connect a jumper wire across the terminals on the switch and see if it runs better. Then, you'll know!
