Hey Bob
ron,ar
07-11-2006 14:56:15
Do any of you Nguys use any type of circuit protection on your tractors? I am speaking of fuses and breakers. I know the light switch has a fuse but what about the rest? I sure would hate to see a N burnt up.
Dell (WA)
07-11-2006 17:26:05
 Re: Hey Bob in reply to ron,ar, 07-11-2006 14:56:15
Ron..... ..even the original dealer installed headlight switch was "un-fused". Dealer replacement headlite switches are now fused. (20-amp)
Iff'n you'll check, most all 6-volt automobiles were also un-fused. ('cept for the vibrator powered vacuum tube radio).
There is NO LAW that sez you can't do yer own fuseing, but be advised, the 6-volt ignition system is very NON-TOLERANT of voltage drops across fuses and you will gitt weak sparkies.
Remember the 6-volt MANTRA: "keep'em clean, brite'n'tite" and you won't have enny shorts that need protection by fusing..... ....Dell
K.LaRue-VA
07-11-2006 20:14:41
 Re: Hey Bob in reply to Dell (WA), 07-11-2006 17:26:05
It is probably a good idea to also LOOK at your wiring harness once in a while when you are doing the "clean, brite"n"tite" thing. The 52 I am working on started right up and ran great but when I looked closely at the wiring harness, I lost count after finding at least 26 breaks in the old rubber insulated wiring. Some of it had been re-taped a couple of times, but the entire harness should have been replaced a LONG time ago. The generator was working fine so when I get it back together with a new harness it will still be a 6-volt system.
