what works for me..
ron,ar
08-28-2006 21:11:04
I have removed several using the same method Bob uses, but it is nerveracking. I just start my bead at the bottom and run it straight up the sleeve. I don"t try to get any penetration, the opposite in fact, you want to "draw" the sleeve tighter (smaller) from the inside of the bore. It works for me. A few years ago I sold a complete flathead ford sleeve remmover/installer set that I had gotton from a Ford dealership going out of business. I wish I had kept it as it was genuine Fomoco where as the one I have is not. I just use it to install the sleeves, I use the crackerbox welder to remove them. Worst case is when some has JB welded them in place:^(
