not the answer you want...
ron,ar
09-04-2006 08:32:40
Most big stainlessunits are built for looks, not function. A good simple Weber kettle will usually cook circles around those big semi-stainless do-alls.
Having said that about "simple"... I have a big BBQ grill made from an old hinged "munitions" container, built by an employee of one of the now closed army bases. I have it set up where I can use propane or charcoal. It is almost 5 ft long, almost 2 ft wide, has wheels on one end and easily moved around. It cooks great!!!!
If you want looks, want to impress your neighbors with what sits on your deck, buy you one of those high $ stainless grills that you replace when wore out. If you want function, want to have the freinds and neighbors admiring your BBQ skills and taste, have you one built that will actually grill, smoke, and last a lifetime.
hvw
09-04-2006 08:50:54
 Re: not the answer you want... in reply to ron,ar, 09-04-2006 08:32:40
Nah, that's sort of the answer I was expecting. Nobody to impress around here anyway. I used to buy the grills from walmart which I expected to replace fairly often. It's just a little disappointing to me the way these "high end" grills perform.
ron,ar
09-04-2006 09:13:48
 yep in reply to hvw, 09-04-2006 08:50:54
I used to buy those wallyworld propane grills and had to replace the burners almost every year. The humidity here in the south combined with the heat and ash from cooking just eats them up. I guess I came off a little samrta$$ with my reply but didn"t mean too. I was speaking from my own experiances mostly. Took me years to figure out what works best for me. Good luck with your BBQ!
Dixon
09-04-2006 20:19:48
 Re: yep in reply to ron,ar, 09-04-2006 09:13:48
WHEN YA GETRDONE ARE YA GONNA VITE US ALL OVER FOR A TEST SESSION
