Thanks for all the suggestions
Pooh Bear
09-19-2006 18:15:01
Thanks for all the suggestions.
Hope to start checking it out tomorrow.
I scooped dirt (forward) today for about 45 minutes.
Ever now an then there is a miss in the engine.
For now I got a lot to check out.
Will let you know what/if I find anything.
When I say I hit the pile pretty hard sometimes,
I mean hard enough to about knock me off the seat backwards.
I got the pile knocked down enough now I can do
all my scooping forward, so no more hard knocks like that.
I was worried I was gonna break something.
Thanks.
Pooh Bear
Hobo,NC
09-20-2006 04:39:05
 Re: Thanks for all the suggestions in reply to Pooh Bear, 09-19-2006 18:15:01
Izz it a stumble like you quickly turned the ignition switch off, or a skip like you lost a cylinder. I am still think段n a wire段n problem that you kin eliminate or a problem with the dist. Sumwere. To check for a cross fire of the plug wires spray with water to find broken insulation, also spray the coil, use a hand held spray bottle all you need izz a mist. Wiggle the wire段n harness. Sumin may be loose.
