I agree...
ron,ar
10-20-2006 11:13:54
There are two different "vents" mentioned on this thread. The one I am referring to is the BOWL vent that allows air on top of the float bowl to escape the bowl as fuel enters. If it is clogged the air is trapped and will not allow fuel to enter. This is especially true if the two halves are a really tight fit. Basically air has to get out to let fuel in. Hobo's factory pictures do indeed show the location of this vent in Group 2-engine Section S Fuel System of his PDF file. I have vatted this carb twice, once in Gunk carb cleaner and another time in Napa's brand and washed it with hot water, blew out with compressed air. I finally drilled a small hole in the top of the upper half and temporarily solved the problem. Evidently the vent is plugged internally. Knowing the location will help in opening the passage. It may be that there is a wire or something from a previous attempt to overhaul this carb. Thanks fellas.
