plow mount to a bucket
RWK in WI
10-25-2006 17:54:33
I have one loader that uses a regular snowplow from a truck. We have a plate that bolts to the bottom of the bucket. The plate has four ears sicking up. Two on each side spaced far enough so that they can take one side of the plow mount between them. A hitch pin through the two ears and the plow mount on each side and the plow is on. The lift chain is hooked to the top of the bucket. I hope this helps you.
