Fraternal Greetings!
A. Bohemian
03-22-2007 07:16:22
Quote: " I have done valve clearence on an aircooled VW..."
Brother! Well met!
If you set the valve lash on a flat-head Ford (or almost any other old tractor engine) with the care and accuracy you used on your VW you will have no problems. You will also have to do the job much less frequently.
You may already know this, but water-cooled engines don't generally "eat" their exhaust valves the way the air-cooled VW will if the lash is allowed to creep slightly out of tolerance.
