More Legalese
A. Bohemian
04-04-2007 07:58:09
Using Ohm's Law,
I=E/R
where I is current, E is voltage (no, I don't know why. Some people use V) and R is resistance in ohms:
In the case of a 12 volt conversion:
I=12/1000 I= .012
Or 12 mA. This is a typical grid current in a vacuum tube amplifier, but not good for a Kettering ignition system.
Extrapolating with the original six volt system, I=.006 A, or 6 mA. Not a whole lot of current by any standard. Using P=IE for power consumption, P=.144 watts at twelve volts and .036 watts at six.
Many Kettering systems on this class of tractor (and many cars and trucks, for that matter) work well dissipating about 25 watts. There is a BIG difference between .036 watts and twenty watts.
So what, you ask? Remember the ammeter on your dashboard? Well, let's assume for the sake of argument that the standard ballast resistor on your dashboard develops a high-resistance fault that gives it a value of 1k ohm (not uncommon in sixty-year-old resistors).
In this case, the meter mught wiggle a little at the instant the switch is thrown, but would in all probablity not show any legible deflection from zero, as the current flow is very tiny and the meter is designed to measure accurately more twenty times as much current.
Simple, neni pravda?
dan hill
04-04-2007 16:28:08
 Re: More Legalese in reply to A. Bohemian, 04-04-2007 07:58:09
Your math is suspect.4 amps is more like it...
roger '40 9n
04-05-2007 07:33:48
 Re: More Legalese in reply to dan hill, 04-04-2007 16:28:08
Actually 25 watts at 6 volts is about 4 amps.
Remember: watts is volts times amps.
Roger in Michigan
souNdguy
04-04-2007 08:08:50
I think you probably shoulda posted this to the orginal poster.. not me.. Your preaching to the choir with me.. I did electronics 101 decades ago..
Soundguy
A. Bohemian
04-04-2007 10:01:52
 Of course. in reply to souNdguy, 04-04-2007 08:08:50
Anyone who reads this forum regularly knows you know your stuff, soundguy.
Sorry for the misunderstanding.
TheOldHokie
04-04-2007 08:08:37
Because E = electromotive force
TOH
