Found it! Thanx, guys.
POOT
04-04-2007 18:21:01
Both governor levers are loose. The one that connects to the carb linkage has forward & rear slack, & not letting the idle speed adjuster return to the stop. Looks like it's time for new needle bearings & or shims.
8N'r--WI
04-05-2007 03:55:45
 Re: Found it! Thanx, guys. in reply to POOT, 04-04-2007 18:21:01
Poot---try lengthening the long rod that goes from the governor to the hand throttle arm assembly---
Doing that applies more "back" pressure (toward the driver) on the short rod from the governor to the carb.
That in turn pushes your idle adjusting screw down to the stop which might be part or all of the problem----just fixed the same issue on one of my 8N's a few weeks ago.
I also had worn spots on the gov. balls that was a part of the problem---Tim
POOT
04-05-2007 12:35:01
 Hey, 8N'r--WI in reply to 8N'r--WI, 04-05-2007 03:55:45
I tried yer suggestion & sho nuff.. it worked like a champ! Nudder question.. there is a steel "donut" that slides back & forth on the rod... what does it do?
Thanx alot, Tim.
Poot
8N'r--WI
04-06-2007 05:18:18
 Re: Hey Poot--Mysterious Donut on your tractor in reply to POOT, 04-05-2007 12:35:01
Poot---glad to here that my suggestion fixed your problem---
You say "there is a steel "donut" that slides back & forth on the rod..."...what does it do?"
I believe you are asking about one of the 2 governor rods? If so, There should not be anything at all sliding back and forth on the rods....however, that doesn't mean that a P.O. didn't improvise up a sliding weight system rigged up "donut fixum trick" to try to solve the problem you were having.
If the donut is on the short rod, he/she may have thought the xtra weight would help push the idle adjustment screw down--remember when you pushed the screw "down" on your tractor it would idle better?
Without a pic of this "donut" MY wild guess could be that one of the long rods ends just wore out, slipped over the springy thing inside of it, and is just joy riding up and down the rod. You would see that the long rod then would not have a complete adjustable tip on the end where it fastens to the governor and the hand throttle arm.
The short rod ends are not adjustable.
I would be interested in seeing a pic of this "donut" though. ----Tim
