del
RP-40-9n
04-16-2007 21:55:41
my 9n has a toggle switch, is it also in that category? or is it just the original type switches that are weak? RP
Dell (WA)
04-17-2007 08:18:20
 Re: del in reply to RP-40-9n, 04-16-2007 21:55:41
RP..... ...most likely, yer toggle switch is mor'n adequate, my replacement marine grade toggle switch is rated 25-amps. But thats because I bought it and know how to replace it. Yours? who knows? The thing is the OEM and replacement keyed ignition switches are only 5-amps (barely adequate) and causes weak sparkies after years of wear and is the 2nd most likely cause of weak sparkies after bad ignition points..... ..Dell, the razor
