The Devil, Etc.
A. Bohemian
04-20-2007 20:08:16
What exactly is the engine doing that makes you think the governor and carb are not happy together?
WarEagleDan
04-21-2007 05:50:36
 Re: Carb-Governor in reply to A. Bohemian, 04-20-2007 20:08:16
Just not sure which to adjust first. Seems like adjusting one throws the other one off. I can"t see any difference at all when adjusting the idle mix. It runs good under any load but does not have a smooth enough idle to really tell any thing about it. thanx
Dell (WA)
04-21-2007 07:51:16
 Re: Carb-Governor in reply to WarEagleDan, 04-21-2007 05:50:36
Dan..... ....always adjust yer carb LAST. Eff'n yer governor upsets yer carb, DISCONNECT yer carb-to-governor rod (as you must know, they "snap" apart, and is adjustable for a no tension, snap-together length)
Always adjust yer carb for FASTEST IDLE, not smoothest idle. Understand? Remember yer side-pointing idlemix is BASSACKWARDS; out for lean, IN for ENRICH. My idlemix is about 1/4 turn. Yours should be close for a SLOOOooow 400rpms idle..... ..Dell
