Common Test
A. Bohemian
04-23-2007 08:35:02
Many on these boards keep a spare spark plug pre-gapped at 3/16" or so. Then, all you need to do is pull a spark wire and pop it on the spare plug, hold the plug up against the block, and turn "er over.
I"ve done the same test lo these thirty years or more by holding the spark wire approx. 1/4 inch from block, but this method is impracticable if the wires have boots; and the 3/16" plug method gives much more consistent readings and is easily repeatable, so I"ve adopted it myself.
If you fail the spark test, and are having trouble finding the bad part, don"t forget the ignition switch. They are apparently very problematic and many on this board were ready to start rending their garments until Dell convinced them to TRY substituting a new switch, at which point the spark became noticeably better.
