Thanks for the Feedback
A. Bohemian
05-05-2007 21:43:45
Quote: "I think If I had a problem there it would affect the way my tractor starts and runs."
Yep. The fact that you are NOT showing a 3 amp or so discharge with the ignition thrown but the engine runs well can only mean the ammeter is defective or installed incorrectly.
The ignition system needs 3 amps or so to make good spark, and I imagine if the engine runs well and can pull a load, it is probably getting it.
In addition, if the voltage check prescribed by Bob shows a hair over seven volts or a little better, you should be showing several amps charge when the engine is running.
A question: what kind of experience do you have with electronics?
