Clarification
A. Bohemian
05-07-2007 11:35:18
Quote: "If, after running the above spark test, it is found that removing the spark wire from each cylinder in turn DOES NOT affect the way the engine runs, the problem is likely to be in systems common to all cylinders."
I probably should have written, "If, after running the above test, it is found that removing the spark line from each cylinder has the same result regardless of which line is removed, then the problem is likely to be in systems common to all cylinders."
