Over Running Coupler
S Russell
05-10-2007 19:53:09
As a newbie with an 8N with a 5' Howze brush hog. Could someone direct me to information on the Over Running coupler. I was advised to insure and use it for safety. What does it look like. Is there perhaps a website of a seller. Thank you
Dell (WA)
05-10-2007 20:47:29
 Re: Over Running Coupler in reply to S Russell, 05-10-2007 19:53:09
third party image
Russell..... ...here is a picture of an ORC (over running coupler). They come in 4-different PTO size and sexx combinations so you don't haffta use extra adapters. The N-Tractor PTO originally came as a 1-1/8" 6-spline. In the mid-50's the ASAE changed PTO specifications to 1-3/8" 6-spline. So having a "built-in size-change" is advantageous. How do you know which PTO size you have on yer tractor, measure it, simple eh? It ain't a micrometer kinda thing.
ALL modern brushhogs are 1-3/8" female 6-spline sliding PTO shaft. You will haffta sacrifice several hacksaw blades to the PTO gods and cut BOTH sliding ends about 3"-SHORTER. Don't worry, PTO shafts are made to be cut, but they're tuff'n'hell steel. Cuttin' torch leaves a too-ruff end-cut, so you really haffta dress-it with grinder. Install with 5/16x2" rollpin thru the removable grease zerks.
The ORC prevents all that rotary inertial energy from back-driving thru yer PTO shaft into yer tranny and out the diffy where yer engine clutch and BRAKES DON'T WORK. And will drive yer tractor into the corner of the barn, fencepost, powerpole, creekbank, irrigation ditch, wife's car (don't ask). $60 (cheap)..... ..Dell the ORC safety preacher
S Russell
05-11-2007 05:14:19
 Re: Over Running Coupler in reply to Dell (WA), 05-10-2007 20:47:29
Thanks Dell, That device appears to be on mine, but if you don't know what it is, like me, I have to ask for Safety Sake.
Thank you
8N'r--WI
05-11-2007 06:31:04
 Re: Over Running Coupler in reply to S Russell, 05-11-2007 05:14:19
S-----take a minute, and go to the Research and Info section to the left of your screen.
Go into the Articles Section and read some great info in the "Choosing, Mounting and Using a Brush Hog Type Mower" article.
Hope it helps with the Safety Issue----the hog will bite you or someone else if you are not careful----they are fun to use though---Tim
