picture of shifter
ratface
05-31-2007 07:03:30
third party image
take a look on the inside. What is the function of the red button on dash? those arn't airbrakes are they?
duey
05-31-2007 08:33:07
 Re: picture of shifter in reply to ratface, 05-31-2007 07:03:30
The red lever device on the dash is a MICO Brake lock... not AIR brakes, but you step on the brake hard then throw the lever... it holds brake pressure on all four corners... often found on tow trucks or wreckers... very handy.
I also see what looks like an electric trailer brake unit under the steering column... It SHOULD be plumbed to the hydraulic brakes.... so when you step on the pedal, it applies the trailer brakes automatically. OR, you apply them manually by moving the lever to the right...
Clean it up and add paint... don't start it unless you seriously need it... or re-engine it to maybe a 350 V8... It'll keep you entertained.
duey
Bob
05-31-2007 08:30:59
third party image
It looks like a manually-operated "linelock" to hold the rear hydraulic brakes engaged for use as a parking brake.
