Hey, SouNder....
Poot
06-09-2007 11:26:12
no, I didn't turn the wheel from lock to lock cuz I had to hold the grease gun tip on the zerk. BUT, why couldn't I just fill the entire thing plum full of cornhead grease, from the lower sector housing, all the way up? That would take care of the lower bearing as well. Think that would work?
Dell (WA)
06-09-2007 11:49:51
 Re: Hey, SouNder.... in reply to Poot, 06-09-2007 11:26:12
Poot..... ..the 2N steering gearbox is splashed lubed from oil-slinger on tranny gears. And that is why you found a separate greeze zerk for upper steering wheel hub on your 2N.
Both the 8N's steering gearboxes are sealed self-lube boxes that NEED the heavy sticky corn-oil to lube the bearings and gears. The 8N's do NOT have the same kind of upper steering wheel hub that yer zerked 2N steering wheel has..... ..Dell
Poot
06-09-2007 12:00:45
 Ahh, I see.... in reply to Dell (WA), 06-09-2007 11:49:51
I was going by the pictures in the FO-4 & the MPC, where it looks like the bottom of the sector housing of the 9N / 2N is closed off. Thanx, Dell
Poot
soundguy
06-09-2007 12:36:44
 Re: Ahh, I see.... in reply to Poot, 06-09-2007 12:00:45
Yep as dell said the 2n steer box is open. My comment about moving the wheel was to get the bearing moving so that it would take some grease or oil ( though probably not much )
Soundguy
Poot
06-09-2007 13:23:07
 SouNdguy.... in reply to soundguy, 06-09-2007 12:36:44
I understand... thank you.
Poot
