Check the Firing Order
A. Bohemian
06-18-2007 17:42:29
Did you accidentally switch wires while replacing the plugs, perhaps?
1243, same as Model T, Model A, etc. Number one is the cylinder closest to the radiator.
Delco systems and similar have a notch in the distributor housing to help you identify where the rotor position for cylinder #1 is on the distributor; someone else will have to tell you how to find it on your Ford.
